axle stuck in half shaft
Old Oct 6, 2003 | 07:10 PM
marc.ejay-twenty's Avatar
Default axle stuck in half shaft
so my driver side axle won't pop out of the half shaft on my 00 si. i had this problem the first time i changed a driver side axle, but eventually got it to come out after about an hour of me and my friends yanking on it. this time, it seems like it won't go. i've searched and i've tried: prybar, screwdriver, small hammer with chisel, and yanking. none of these have worked.
i'm thinking i should just buy the biggest hammer i can find and hit the axle outwards from the half shaft. anyone else have any suggestionS? thanks in advance
Old Oct 7, 2003 | 12:35 AM
Default Re: axle stuck in half shaft (marcdogg816)
ttt
Old Oct 7, 2003 | 04:44 AM
pro1342's Avatar
Get a bigger hammer and beat the inner joint off of the intermediate shaft.
Old Oct 7, 2003 | 06:01 AM
T4eg's Avatar
Default Re: (pro1342)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pro1342 &raquo;</TD></TR><TR><TD CLASS="quote">Get a bigger hammer and beat the inner joint off of the intermediate shaft.</TD></TR></TABLE>
thats what you gotta do
Old Oct 7, 2003 | 06:06 AM
whitelightning's Avatar
Default Re: (BlueHatch00)
driver side is a pita! i used a crowbar to pry it apart G/L
Old Oct 7, 2003 | 07:28 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: (whitelightning)
Just use a prybar, it will comply. If not, use explosives
Old Oct 7, 2003 | 08:09 AM
Aceman64's Avatar
Try prying at it from two sides at the same time. That way it will be coming out straight. Ive never had a problem, but theres always next time.
-Ace
Old Oct 7, 2003 | 09:13 AM
Default Re: axle stuck in half shaft (Aceman64)
thanks for all the replies...an 8 lbs sledge hammer did nicely
Old Oct 7, 2003 | 10:44 AM
pro1342's Avatar
Old Oct 7, 2003 | 12:36 PM
TwoRedEGgs's Avatar
Default Re: axle stuck in half shaft (pro1342)
yeah they usually get scared and fall out when they see you are pissed and you have decided to get a hammer !!!
Old Oct 7, 2003 | 12:42 PM
WundedSaint's Avatar
get a bigass locking plier (vise grips) and lock it unto the shaft, then bang on the plier with a big hammer in th direction you want it to go,should pop out in one hit.
MUGEN_EG95
Jun 17, 2009 03:42 PM
AlexanderTheGreat
Jul 10, 2007 12:11 AM
saikou
Jul 1, 2007 06:22 PM
EG6-SIRII
Aug 18, 2005 03:28 PM
ActiveAero
Jul 4, 2005 05:38 PM
