Axle Set/snap ring install---how?
Old May 9, 2013 | 07:40 PM
unspankable's Avatar
Default Axle Set/snap ring install---how?
Hey guys,
How do you install a new set/retaining ring on the intermediate shaft and cv properly without distorting it?
What snap ring pliers am i meant to be using. Ive already fu'##ed up two rings..
Thanks for your help.
Old May 10, 2013 | 07:24 AM
1992Si's Avatar
Default Re: Axle Set/snap ring install---how?
I gather your asking about item 8.
http://www.acuraautomotiveparts.org/...s=&view=normal
I don't understand why your snap ring pliers won't work. I'm guessing you need to open the ring to get it over the shaft.
Worst case, have the dealer do it for you. May be ask a local repair shop if they can do it.
Old May 11, 2013 | 12:38 PM
Thank you very much for the help. Turned out i was just being an idiot. It's all in the technique . Used a flat head to work it on there gently from the end of the shaft not the groove.
Thanks again
Old Jul 22, 2013 | 10:47 AM
MadVladCivic's Avatar
Originally Posted by unspankable
Thank you very much for the help. Turned out i was just being an idiot. It's all in the technique . Used a flat head to work it on there gently.
Thanks again
I'm having issues as well. I am using a pair of Craftsman lock-ring
pliers. But all that seems to do is deform the lock rings. Managed to
get the set ring on (lighter gauge) and get it re-formed but the
thicker gauge stop ring on the outer joint side will not be reformed
once on. Took it off and reformed it but same thing happened
again. Can you explain your technique?
Thanks.
dodt
Mar 15, 2015 06:40 PM
awps
Oct 7, 2005 06:30 AM
shoebox
Jan 17, 2003 07:58 AM
boomslang
Oct 25, 2001 05:54 PM
