replacing axle seals
need to replace both axle seals, are they both the same part?
the part number i have right now is 91205-PL3-A01 "OIL SEAL (35X56X8) (ARAI)" what does 'ARAI' mean? this is #6 in the picture
because the part listed below that one on majestic's site is 91216-PL3-005 "OIL SEAL (26X42X7) (NOK)" this is #7 but is not in the picture...
so should i order two of the 91205-PL3-A01 ?
should i also replace the set ring clip that goes on the end of the splines?
Re: replacing axle seals
If you are replacing the outer shaft seal (#8) don't be surprised if it doesn't come out in one piece and shreds as your try to remove it. You might want to pick up a metal dental teeth cleaning tool to help pull it all out. I bought one at a flea market for $1 last week. Like anyone of these: http://www.pjtool.com/images/products/detail/3504C.jpg
thanks for not spoon feeding, ron
i found it. main problem i have with majestic is having to randomly guess which system/component category to choose when trying to find something:
#15 would be the right side axle seal 91206-PL3-A01 "OIL SEAL (35X62X8) (ARAI)"
so i need to order:
but i still don't understand what "OIL SEAL (26X42X7) (NOK)" is for
as for the set ring, those are both the same - shown as #9 in this picture:
so i need to order 2 of the 44319-SR1-003 (set rings)
so i need to order:
- 91205-PL3-A01 left side axle seal
- 91206-PL3-A01 right side axle seal
That would be part #7 of the clutch housing side and would be the Input Shaft oil seal. It keeps oil from leaking into the flywheel housing area.
To replace it you must crack open the transmission case and you should go ahead and replace the Input Shaft Bearing too at the same time as they are known to wear the fastest of all the bearing and a known problem with Honda D series manual transmissions.
Oh and if you are not partial to majestic's web layout and design you can also use hondapartsnow.com as their format might be easier for you to navigate.
Iloveyourhonda92
04-15-2012 08:29 PM
Former User
05-27-2010 10:52 AM
