AXLE PROBLEMS!! PLEASE HELP!!
Old Mar 11, 2004 | 07:50 AM
civicqm's Avatar
Default AXLE PROBLEMS!! PLEASE HELP!!
I put in new axles in my hatch to fix a problem I was having while turning. Put the new axles in same problem!!! Same clunking sounds and annoying bucking when making turns. The car is fine on the straight, but when I turn it is loud and bucks. I have a JDM GSR Tranny with LSD, and I was wondering if maybe I was getting some axle bind? The car is lowered with Skunk2 Coilovers and KYB's do you think it is too low? I am not sure what axle bind is or what the symptoms are. If anyone could help it would be greatly apperciated. Please post anything you know. Thanks so much.
I posted this in the all motor forum too, so mayber you all can help here more...Thanks
Old Mar 11, 2004 | 07:58 AM
BoostedEF's Avatar
Default Re: AXLE PROBLEMS!! PLEASE HELP!! (civicqm)
The bucking sounds might be your LSD . I got a KAZZ and when I make tight turns it makes a noise . I think its normal for all LSD's to make a noise my Expedition makes a noise 2 .
Old Mar 11, 2004 | 08:13 AM
civicqm's Avatar
Default Re: AXLE PROBLEMS!! PLEASE HELP!! (BoostedEF)
Yeah I know that they make noise but this is like a slapping sounds like metal against metal if you know what I mean. Sounds like something is slipping inside the tranny....Who knows...Thanks for your help tho
Old Mar 11, 2004 | 08:29 AM
matix's Avatar
I have same problem with the drivers side axle on my h22 in my accord. It was popping out at the intermediate shaft then clunking on corners. So i just made the metal ring a little bigger and axle hasnt popped out scince. Maybe check intermediate shaft to see if its popped out.
Gonzo_SiR
52
Mar 24, 2021 11:39 AM
dapek
Nov 30, 2009 09:10 PM
laziebun
Aug 14, 2008 02:54 PM
astig* DC2
Sep 20, 2005 12:23 PM
hybrid901
Jun 4, 2002 01:46 PM
