axle going bad?
Old Jan 21, 2002 | 12:28 PM
Greyout's Avatar
Default axle going bad?
I am getting a vibration when the drivetrain is under load. Is it possible for a bad axle to cause this, even if it doesn't give the normal clicking sound when turning?
I looked under my car and there is quite a bit of grease around the boots....
Old Jan 21, 2002 | 01:05 PM
Kamin's Avatar
Default Re: axle going bad? (JDM LUDE)
if theres grease around the boot, its torn or bad.
im going through the same thing with my b16 right now
its spitting grease from the boot
taking it off in about an hour.
Old Jan 21, 2002 | 01:09 PM
Greyout's Avatar
Default Re: axle going bad? (KAMiN)
I know the axles need to be replaced - I was just trying to figure out if thats gonna fix my vibration problem.
Old Jan 21, 2002 | 02:00 PM
bob01721's Avatar
Could be the inner CV joint going.
When the outer joints go, you'll hear that clicking sound when you turn the wheel. When the inner ones go, you'll frequently get a shudder or vibration when you accel or decel.
grkblood13
Transmission & Drivetrain
Apr 2, 2009 05:09 PM
tRex99
Sep 14, 2004 09:53 AM
JDM R
12
Aug 27, 2004 04:15 PM
95GSRTT
Aug 4, 2004 10:01 PM
d_mina
Nov 27, 2003 12:09 PM
