automatic tranny problem
Old Dec 19, 2007 | 04:53 PM
dc2go's Avatar
Default automatic tranny problem
i belive its the tranny prob not sure. sometimes on acceleration the car doesnt move...the rpm raises but car just revs? this happened after a radiator removal...
Old Dec 19, 2007 | 05:20 PM
onepoint6i's Avatar
Default Re: automatic tranny problem (dc2go)
have you checked the fluid level?
Old Dec 19, 2007 | 06:44 PM
hilltopgraphics's Avatar
What model & year? D-light flashing or CEL? Have you checked to see if you might have damaged a harness wire, pressure switch, shift solenoid or anything else during your radiator swap?
Old Dec 20, 2007 | 09:08 AM
Gearspeed-Performance's Avatar
Default Re: automatic tranny problem (hilltopgraphics)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hilltopgraphics &raquo;</TD></TR><TR><TD CLASS="quote">What model & year? D-light flashing or CEL? Have you checked to see if you might have damaged a harness wire, pressure switch, shift solenoid or anything else during your radiator swap?</TD></TR></TABLE>
Old Dec 20, 2007 | 04:57 PM
dc2go's Avatar
no check engine light or anything.. dont see any wire damage. pressure switch? shift solenoid? the fluid that came out of the radiator...that fluid is from the p/s correct?
Old Dec 20, 2007 | 07:04 PM
onepoint6i's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2go &raquo;</TD></TR><TR><TD CLASS="quote">no check engine light or anything.. dont see any wire damage. pressure switch? shift solenoid? the fluid that came out of the radiator...that fluid is from the p/s correct? </TD></TR></TABLE>
no its atf..check your level..start it..then shut it off then check the level..
HT Chaplain
Welding / Fabrication
12
Dec 1, 2007 04:13 PM
OUT_OF_ORDER_DB7
Northern California (Sales)
Oct 4, 2007 07:12 AM
NorcalHB94
12
Apr 22, 2005 07:20 AM
JdmAcclude
Honda S2000
Dec 5, 2003 09:06 PM
Artful Dodger
Jul 7, 2003 09:21 PM
