Honda S2000 Honda S2000
thermo switch install?
Old Dec 5, 2003 | 03:21 PM
JdmAcclude's Avatar
Default thermo switch install?
where is the thermo switch located in the S?
Old Dec 5, 2003 | 09:06 PM
evil vapor's Avatar
Default Re: thermo switch install? (fullmoon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fullmoon &raquo;</TD></TR><TR><TD CLASS="quote">where is the thermo switch located in the S? </TD></TR></TABLE>
it's on the bottom of the radiator located on the driver side, you can't miss it. It's brass and has a wire harness coming from it. If you can locate the drain plug on the radiator, it's on the opposite side. If you remove the plastic shroud under the car, you'll be able to see it very easily.
G2_Fella
Sep 18, 2007 11:27 PM
court
Jan 29, 2006 06:05 PM
fanta!
Jun 16, 2005 03:36 PM
crewjones
Oct 27, 2003 06:51 AM
