attn tranny experts: a question about syncronizers...
Old Mar 26, 2003 | 10:58 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default attn tranny experts: a question about syncronizers...
i have a friend who wants to swap his b16 hydro tranny for my ls! catch is, his 3-4 grinds at high rpm. other than that it's butter. i have a spare ls tranny sitting around opened up and it had a bad 2-3 syncro. i am wondering if the one i need in the ls (3-4) is compatible in the b16? y/n, any solid answers would be greatly appreciated. i am trading regardless, but it would be nice if i had the fix in my garage. thanks.
-kevin.
Old Mar 27, 2003 | 01:17 AM
K20  EG's Avatar
Default Re: attn tranny experts: a question about syncronizers... (not so civic)
your problem is the hubrings they typically wear out and cause that awful grinding
you can buy the set at honda for around 200 and they come in 1-2 , 3-4 and 5th gear sets
and no b16 synchros are not compatible with ls
Old Mar 27, 2003 | 07:54 AM
Default Re: attn tranny experts: a question about syncronizers... (RevhardEG)
thanks for the helpful info revhard .
Old Mar 27, 2003 | 08:08 AM
Nameless RB26's Avatar
Wow. This guy can diagnose your problem over the internet. Pure genius.
Old Mar 28, 2003 | 02:03 PM
madslackin's Avatar
It's worth it to open up the b16 trans and see if it is in fact the synchros that are worn. 9.5 out of 10 trannies I see that grind do not have bad synchros but rather the synchro teeth on the gear itself (the hubring as revhard called it) are worn. In this case, the only thing you can do to fix it is replace the affected gears.
Synchros from hydro LS and b16 trans should be identical.
Also, if you're experiencing grinding in 3rd AND 4th there's a good chance the problem is related to your 3/4 shift fork so that's worth checking out as well.
Justin
88 EF Hatch
Transmission & Drivetrain
Aug 1, 2009 10:28 AM
hatch96y7
Aug 16, 2007 10:32 PM
2wheelhunter
Dec 28, 2006 05:56 PM
jarvis199
May 7, 2005 07:51 AM
Lshatchy91
Jun 30, 2004 11:23 PM
