ls tranny question
ls tranny question
i read some where before that the ls tranny and b16 tranny have the same gear ratios. but the only diffrence is the final drive.
if this is true can i swap final drives and have a b16 tranny out of my mint ls tranny
Re: ls tranny question (doood)
the b16 has shorter gears all around. the ls is more gas mileage oriented with longer gears. ls final drives are po pular in b16 trannys for interstate driving.
Re: ls tranny question (hatch96y7)
B16 tranny are way shorter then LS ones.
The B16 tranny inteands to go out after a while cause of the short gears and high rpm's that it's in.
And you'll get shity gas milage if you use a B16 tranny.
Re: ls tranny question (eG6 driver3)
BUT I HAVE SEEN IN A CHART WHERE they show all tyhe gear ratio of b sereis tranny and the say the only diifrence between the ls and b16 is the final drive.
b16a and ITR (USDM) have the same gear ratio.
1st 3.230
2nd 2.105
3rd 1.458
4th 1.107
5th 0.848 (JDM SiR II and USDM ITR) and 0.875 (99-00 Si USDM)
reverse 3.000
LS S80 Gear ratio (94 UP)
1st 3.230
2nd 1.900
3rd 1.269
4th 0.966
5th 0.714
reverse 3.000
Modified by crazyguy at 11:06 AM 8/15/2007
1st 3.230
2nd 2.105
3rd 1.458
4th 1.107
reverse 3.000
1st 3.230
2nd 1.900
3rd 1.269
4th 0.966
5th 0.714
reverse 3.000
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch96y7 »</TD></TR><TR><TD CLASS="quote">BUT I HAVE SEEN IN A CHART WHERE they show all tyhe gear ratio of b sereis tranny and the say the only diifrence between the ls and b16 is the final drive.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood »</TD></TR><TR><TD CLASS="quote">http://allmotorhonda.com/techp...s.htm</TD></TR></TABLE>
hatchattak
08-26-2003 07:44 AM
