ATTN BRAKE PRO'S! need help. abs light on, checked code, this is whats wrong.
Old May 23, 2005 | 07:28 AM
  #26
JimBlake's Avatar
Default Re: ATTN BRAKE PRO'S! need help. abs light on, checked code, this is whats wrong. (vtec-adykt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec-adykt &raquo;</TD></TR><TR><TD CLASS="quote">I know i need to bleed the brakes and master now...</TD></TR></TABLE>You can't ever install a master cylinder without getting some air in there. In fact, since the air was introduced up at the MC, you'll have to bleed LOTS of fluid thru each wheel. From my experience, it's gonna seem like all the bubbles are gone, but then you'll finally get some more.
Old May 24, 2005 | 01:46 PM
  #27
vtec-adykt's Avatar
Default Re: ATTN BRAKE PRO'S! need help. abs light on, checked code, this is whats wrong. (JimBlake)
the master cylinder WAS my problem! I forgot to bench bleed the m.c., but i bled it first while installed on the car, then the rr wheel, lf, lr, and rf. i could tell the pedal was getting stiffer, which was a good feeling. But when i took it for a test drive, it definitely helped me stop. the pedal travel was just a still a little too far, which i'm assuming there is still air in the system. But at least i found my problem.
jeffrox626
Mar 5, 2011 11:20 AM
Fliplm0de
Nov 15, 2008 10:57 AM
SpeedFreek34
Jul 22, 2007 05:43 PM
allmotorEG-SI
Dec 27, 2004 06:13 PM
fanatic
Nov 21, 2003 05:40 PM
