ARP headstud question..HELP!!!!!
Old Aug 19, 2002 | 02:08 PM
BoostedSi's Avatar
Default ARP headstud question..HELP!!!!!
Do i just put the arp thread sealer on the threads and let them dry then torque it down..or do i need to put the sealer on and bolt it down then let it dry..?? Also, how long do i have to wait for it to dry? or do i even need to wait?
btw, headgasket started leaking amonth after i put those studs in last time. I put the sealer on, torqued it and drove on it after a few hours.
Old Aug 19, 2002 | 02:21 PM
sgT's Avatar
sgT
Default Re: ARP headstud question..HELP!!!!! (BoostedSi)
there is no thread sealer.
make sure if you use the arp lubricant that you torque to 70lbft. if you use oil
use 80 or 85lbft whatever arp recommends
Old Aug 19, 2002 | 02:23 PM
BoostedSi's Avatar
Default Re: ARP headstud question..HELP!!!!! (sgT)
The studs came with arp thread sealer... So i shouldnt use that? and get the lube? THanks
Old Aug 19, 2002 | 02:26 PM
sgT's Avatar
sgT
they come with lubricant, not sealant
Old Aug 19, 2002 | 02:27 PM
BoostedSi's Avatar
mine came with arp thread sealer...Is that the right lube theN? I guess i'm just gonna go get loc tite and use that. Thanks for the posts.
Old Aug 19, 2002 | 02:28 PM
sgT's Avatar
sgT
all the packages i get have lube written on them.
Old Aug 19, 2002 | 02:30 PM
BoostedSi's Avatar
Mine didnt come with any lube package. The guy at summit told me to order a bottle of arp thread sealer, so i got that.
btw, i know what ur talking about with the lube package, that came with my rod bolts.
Should i use loc tite or motor oil torqued to 80ftlbs??thanks
Old Aug 19, 2002 | 02:36 PM
sgT's Avatar
sgT
you can go buy some muly lube and go 70 or use motor oil and go 80-85.
i dont remember the exact torque value for motor oil since i always have
moly on hand
Old Aug 19, 2002 | 02:38 PM
BoostedSi's Avatar
Do i put the assembly lube on the threads that go into the block? or just on the washers and nuts? Also wuold u recommend using the loctite on the threads? I really appreciate your help.
Old Aug 19, 2002 | 03:23 PM
sgT's Avatar
sgT
just on the end with the nut.
dont use loctite
Old Aug 19, 2002 | 05:15 PM
tinkerbell's Avatar
i would suggest using hte ARP moly assembally lube on both ends of the studs. incase you need to remove tham at some stage...
the box of studs should have had lube in it already...
the loctie/thread seal is only for other applications...
HTH,
t..
Old Aug 23, 2002 | 10:12 PM
ElectronMan's Avatar
Default Re: ARP headstud question..HELP!!!!! (tinkerbell)
Do the bolts extend into the water jackets? This is off ARP's page and it says something about thread sealer. Dont know if this helps or not.
http://www.arp-bolts.com/pages/produ...s/how_tos.html
zerovandez
Aug 6, 2006 03:51 PM
LSVTEC 91 Civic
May 22, 2006 05:39 PM
user 98292739
Apr 1, 2005 08:09 PM
JDMlyfestyle
Nov 17, 2004 04:05 PM
BoostedSi
Aug 19, 2002 03:45 PM
