arp head bolts installation????
Old Apr 30, 2003 | 06:53 PM
warwagon's Avatar
Default arp head bolts installation????
do you need to hand tighten them then tourque, or jam nut and tighten then tourque
Old Apr 30, 2003 | 08:22 PM
aeolus's Avatar
Default Re: arp head bolts installation???? (warwagon)
if you mean head studs,the studs are supposed to be finger tight to the bottom.
Old Apr 30, 2003 | 09:25 PM
2.2motore's Avatar
when i put mine in i snuged them up a little work fine for me.
Old Apr 30, 2003 | 10:14 PM
Darin D.'s Avatar
snug them in by hand. make sure they are all level. apply moly lube to threads.. then do 26 ft lbs first pass 63 second pass and 75 third. This is how i've always torqued arp head studs and i've never had a problem. I think the instructions in the arp box say 70 ft lbs with the moly lube and 80 ft lbs with regular oil.
Everyone has their own opinion on what to torque them to though. i do it to 75 ft lbs and i've never had one problem with them on many different engines.
Old Jul 25, 2003 | 08:13 AM
luckypon7's Avatar
Default Re: arp head bolts installation???? (Willis)
do i take off the whole head? can i just take the cam rods off and take out the bolts with out removing the head? that would be alot to do taking tubes off and disconnecting this and that.......
oranginal
May 2, 2006 11:14 AM
dumpeDc2
Nov 4, 2004 08:07 AM
ef8rex
Dec 24, 2003 04:32 PM
Convoy
Mar 5, 2003 01:02 PM
