apexi vafc 2 help
Old Jan 26, 2009 | 08:51 PM
b18egchuy's Avatar
Default apexi vafc 2 help
So I just got thru hookin up my vafc2 and it went pretty good, til when I went 2 adjust my custom settings, I tried 2 save them and I thought I did till when I turned on the car they were all messed up and off of what I had set them to, is there somethin I did wrong for the memory 2 not save them or is there a certain way 2 save them??? (Btw I bought the vafc with no manual so I only adjusted the points I knew the meaning to) also if I could get help on the meanings, it would be highly appreciated!!!
Thnx.
Old Jan 26, 2009 | 10:42 PM
mouab18c1's Avatar
Default Re: apexi vafc 2 help
The Vafc is useless to be honest. I would just take it out if you don't know how to mess with it
Old Jan 27, 2009 | 09:05 AM
b18egchuy's Avatar
And that's why im on here trying 2 get help so it won't be useless and a waste of money!
Old Jan 27, 2009 | 09:21 AM
mouab18c1's Avatar
its hard... alot things fall into play....i can tell you that no one will be able to tell you what to set your settings at without knowing whats done to the car, yada yada
Old Jan 27, 2009 | 03:17 PM
patriot's Avatar
Any changes you make are set. You don't need to 'save' anything.
You need to make sure you have your wiring correct. They're simple units, but you need the manual. I have one, but I don't have a scanner so it's of no use...
...and mouab18c1, you're useless here as you haven't even tried to answer his questions.
Old Jan 27, 2009 | 03:20 PM
patriot's Avatar
http://www.apexi-usa.com/pdfInstallation/25.pdf
Old Jan 28, 2009 | 08:53 AM
mouab18c1's Avatar
well obviously you're the smart one here..LMAO....dont you think if he can't even get the settings to set where it is then he shouldnt be touching it? just wait til his car starts to run all funky in shyt...im just giving him a sense of mind so he doesnt mess up his air/flow...thats why people upgraded to chip ecu's
sleepyH22
Nov 12, 2006 09:30 PM
hip_hop_s0ulchild
Aug 23, 2005 10:09 PM
NVMYSi
Sep 11, 2002 10:54 AM
