Apexi VAFC
Old Dec 8, 2001 | 12:42 PM
Drew408's Avatar
Default Apexi VAFC
i just installed my apexi vafc...whenever i floor it...my car bogs and kicks back at 6500. is there a way where i can change that on the controller? i cant seem to find a way. i need it to let me rev up to redline at least.
would it be a wiring problem or just need to do it through the controller?
[Modified by Drew408, 9:43 PM 12/8/2001]
Old Dec 8, 2001 | 12:45 PM
rioninja's Avatar
Default Re: Apexi VAFC (Drew408)
You didnt properly initialize the controller did you?
Drew408's Avatar
Default Re: Apexi VAFC (RioNinja)
i did
Old Dec 8, 2001 | 01:17 PM
rioninja's Avatar
If you initialized it proper, then it should have no affect on the way the engine runs -if- you leave everything at stock settings. You probably just have a loose wire or something. Also there are wires that need to be spliced in a different distances from the ecu, make sure the correct wire is closer.
Old Dec 8, 2001 | 02:29 PM
DragII's Avatar
25 Year Member
Yup...your car should run like stock until you start playing with it.
Old Dec 8, 2001 | 03:10 PM
Drew408's Avatar
i think i know whats wrong...i think everything is ok...its just that my check engine light is on and i have to go get it reset....if the engine light is on...the rev limiter comes in earlier...correct? thats my problem.
Old Dec 9, 2001 | 09:42 AM
John's Avatar
New User
if your CEL is on, most codes will put your car into "limp mode," kinda like a safe mode for your computer...
Drizzo
Nov 26, 2005 09:35 AM
hatchback_al
Jun 15, 2004 08:48 PM
DOHCDOHCwhosthere
Feb 16, 2004 01:58 PM
chrisir19
Sep 23, 2003 08:42 AM
