NEED help on apexi vafc
Old Feb 15, 2004 | 11:58 PM
DOHCDOHCwhosthere's Avatar
Default NEED help on apexi vafc
ok i got an apexi vafc1 for 80 bucks and it came with the stand and the controller and the controller has a wire with a conecter at the end but i need the other half of the wires or can i just rig it up though what wires i have i know how to hook up but i wanted to know if that would work ??????
Old Feb 16, 2004 | 10:01 AM
fearless_dsm's Avatar
Default Re: NEED help on apexi vafc (Babababonersex)
the other side of the harness is only so you can unplug the vafc to move it around or take it out without having to undo your wiring...you can use it without...just add some extra length of wire..
Old Feb 16, 2004 | 10:30 AM
Deluzional's Avatar
the wire with the plug is basically a extension cable, you either have to pick up a few ecu jumper plugs and wire it yourself or ditch the plug and splice your ecu wires to get it to work
BTW 80 for the vafc is a hella good deal
Old Feb 16, 2004 | 01:58 PM
thanks guys
Drizzo
Nov 26, 2005 09:35 AM
4drITR
Oct 30, 2005 02:16 PM
douglas_be
Nov 30, 2003 02:38 PM
weakGOODJunKieS.com
May 30, 2003 10:45 PM
