apexi vafc 2 help
So I just got thru hookin up my vafc2 and it went pretty good, til when I went 2 adjust my custom settings, I tried 2 save them and I thought I did till when I turned on the car they were all messed up and off of what I had set them to, is there somethin I did wrong for the memory 2 not save them or is there a certain way 2 save them??? (Btw I bought the vafc with no manual so I only adjusted the points I knew the meaning to) also if I could get help on the meanings, it would be highly appreciated!!!
Thnx.
Thnx.
its hard... alot things fall into play....i can tell you that no one will be able to tell you what to set your settings at without knowing whats done to the car, yada yada
Any changes you make are set. You don't need to 'save' anything.
You need to make sure you have your wiring correct. They're simple units, but you need the manual. I have one, but I don't have a scanner so it's of no use...
...and mouab18c1, you're useless here as you haven't even tried to answer his questions.
hip_hop_s0ulchild
Aug 23, 2005 10:09 PM
