Apex VAFC or Fields Vtec...MINI ME
Old Mar 30, 2003 | 12:33 PM
Turbo Powa's Avatar
Default Apex VAFC or Fields Vtec...MINI ME
I was wondering if I could still install the VAFC or fields using a non vtec ecu. How would I be able to do this? Anyone have instructions on how to? I dont want to run vtec with an rpm switch cuz the fuel maps.
Old Mar 30, 2003 | 02:32 PM
Turbo Powa's Avatar
Default Re: Apex VAFC or Fields Vtec...MINI ME (Panda EK)
anyone?????
Old Mar 30, 2003 | 02:46 PM
sslude's Avatar
yes it is possible. you connect everything but the VTEC wire. its as simple as that.
Old Mar 30, 2003 | 04:39 PM
Turbo Powa's Avatar
Default Re: Apex VAFC or Fields Vtec...MINI ME (sslude)
so how would the vtec be activated? What would I connect to get the vtec running?
Old Mar 30, 2003 | 09:56 PM
Usdm1's Avatar
vtec wires from the controller to Vtec solinoid/pressure ....
Old Mar 30, 2003 | 09:57 PM
Turbo Powa's Avatar
Default Re: Apex VAFC or Fields Vtec...MINI ME (Usdm1)
so I would need both?
Old Mar 30, 2003 | 11:20 PM
M-EJ1's Avatar
So what you want to do is use non-VTEC ecu on a VTEC motor, and let the VAFC handle all the VTEC duties?
I don't know the answer, I'm just clarifying your question because it seems like you're getting some different answers based on people's interpretation of what you asked.
Old Mar 31, 2003 | 08:33 AM
Turbo Powa's Avatar
Default Re: Apex VAFC or Fields Vtec...MINI ME (M-EJ1)
Top portion of the motor is a vtec head. Bottom is my D16Y7 block. I have a rpm activated switch which I did not install yet because of the fuel problems that it would create. Trying to see if I can install the VAFC only or a fields to take care of everything. I can also use the rpm switch if I have to.
Power Rev Racing
Oct 16, 2005 06:10 PM
cookci
Apr 6, 2004 01:24 AM
jrcrx
Mar 8, 2004 11:37 PM
98R-1144
Nov 4, 2002 05:12 PM
311
Oct 15, 2002 08:42 AM
