Anyone have a TODA Timing Belt?
Anyone have one of these? How do you like it? TODA claims 200% stronger than stock is it worth the $180.00 they want for it?
Re: Anyone have a TODA Timing Belt? (sgT)
Do people really snap their OEM belts that often? If I were that paranod about it, I would just change my timing belt every 45k instead of 90k.
Re: Anyone have a TODA Timing Belt? (inspyral)
People that were using big cams such as Toda B and C were having problems with timing belts stretching and cracking. Thats why Toda cam out with a "stronger" belt. Power Enterprises also makes one, basicallly the same, but a different color and the PE is cheaper
Re: Anyone have a TODA Timing Belt? (dabomb)
the toda belts are actually alot better in the since that they do not stretch as much. OEM belts stretch as the motor warms up. As fo snapping belts well...... that is all in how tight you put it on. I have it and do buy them when I am putting new motors together. The name says everything.... they don't make crap like others.
As for the cams! I don't run Skunk2 any longer..... they ate up my rocker arms. and good ole David from Skunk2 told me on the phone "o'well I won't fix them"
so that is that, end of that!!!! TODA plan and simple.
Re: Anyone have a TODA Timing Belt? (thegrinch)
My boy Cloyse from CBI all motor civic.. runs a toda belt.. but hes in the PRO drag scene. I havent seen anything like that on a street car.. but toda puts out quality parts!
