Another H22a manual tensioner topic, sorry.
Reciently my h22a's auto tensioner went out. Which caused it to make a loud noise when I let off the gas anything higher than 3.5k and it will stop at around 2k. I got the auto tensioner replaced with a manual tensioner and the noise was completely gone till I drove it on the freeway. The noise is much more quieter but it is still there.
I adjusted the tension on the manual tensioner by:
1) removing the valve cover
2) setting the engine at TDC
3) loosening and tightining the adjuster nut
4) turning the crankshaft 3 teeth counter-clockwise
5) loosening and tightining the adjuster nut.
After doing this I still notice the sound.
Is it possible that something is damaged or do I need to adjust the tensioner again?
You may want to try to adjust the tensioner again and see what happens. Something else may be causing a noise also though.
To adjust the tensioner, you need to loosen the adjustment bolt, turn the crank 3 teeth, then re-tighten the bolt, then double check to make sure it hasn't jumped any teeth..
actually I noticed that it goes away and comes back after a few minutes. Maybe I am not tightening the adjusting screw enough? How hard does it need to be? I cant fit a torque wrench up there.
micah_m
Jul 26, 2013 09:09 AM
crxsirg
Honda CR-V & Element
Feb 17, 2013 04:17 PM
