Oil level question. please help
Old Jul 5, 2008 | 01:23 AM
dumada9's Avatar
Default Oil level question. please help
i know this is probably a noob question, but once the motor has been started and running and you check the oil right after it should be at a low point because oil has already begun circulating through the motor right?
Old Jul 5, 2008 | 02:00 AM
dumada9's Avatar
Default Re: Oil level question. please help (dumada9)
so after i let it sit for awhile its at a normal level, then after driving for about a minute, its all the way down below the first line on the dip stick.
any ideas?
Old Jul 5, 2008 | 02:07 AM
dumada9's Avatar
should i be checkin the oil pressure censor? if so does anyone have info on what it looks like and its location?
Old Jul 5, 2008 | 08:05 AM
96lsvtec-t's Avatar
you are joking right??
Old Jul 5, 2008 | 08:33 AM
95 integra's Avatar
Should be somewhere bewteen the lines when the car is off. Dont check it with the car on because it will vary alot on the oil temp (if its cold the oil will tend to stay in the top of the head and not drain back down as quick as when its hot). Dont worry about the oil pressure sensor....Im not even sure what you're going to check with it.
Old Jul 5, 2008 | 11:44 AM
dumada9's Avatar
Default Re: (96lsvtec-t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96lsvtec-t &raquo;</TD></TR><TR><TD CLASS="quote">you are joking right??</TD></TR></TABLE>
what im referring too is after the motor has been running what is the appropriate level that the oil should be at. -_-
Old Jul 5, 2008 | 11:46 AM
dumada9's Avatar
Default Re: Oil level question. please help (95 integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">Should be somewhere bewteen the lines when the car is off. Dont check it with the car on because it will vary alot on the oil temp (if its cold the oil will tend to stay in the top of the head and not drain back down as quick as when its hot). Dont worry about the oil pressure sensor....Im not even sure what you're going to check with it. </TD></TR></TABLE>
thanks for the info. what i mean by checking the oil pressure censor is checking to see if its off or loose or something.
FRKWOO
Feb 3, 2009 07:20 PM
kevin85193
Jun 12, 2005 11:42 AM
LudeChild
Feb 27, 2005 09:15 AM
Mr. TopFuel
Dec 24, 2004 05:02 AM
XxRoCkMaNxNEOxX
Nov 28, 2004 09:17 AM
