alternators
Old Sep 3, 2009 | 03:31 PM
teamworxek9's Avatar
Default alternators
wondering if anyone knows if the only difference between obd1-2 alternators is the plug?
mine seized up in the bracket and i have a obd1 alternator sitting around. if its just the plug i could just splice in the obd1 plug, just wondering.
Old Sep 3, 2009 | 05:22 PM
Default Re: alternators
please someone has to know.
Old Sep 4, 2009 | 07:32 AM
Newsom91's Avatar
i had a b20 vtec in a obd1 gsr. the harness was obd1 but the alterator was obd2. they just repinned it and it worked fine
Old Sep 4, 2009 | 09:03 AM
likwidchz's Avatar
Yeah all the alt's are the same.
incase you were wondering the pinouts
1 pin is a ground "only when the alternator isnt spinning" this goes to the battery light on the dash.
1 pin is +12 volt <-- you need to supply it 12 volts.
the other 2 pins are charge sense and these go directly to the ecu.
--Aaron
Old Sep 4, 2009 | 04:32 PM
thanx for the help.
sparco562
Aug 23, 2007 07:09 PM
EK FLY
Jan 3, 2007 05:26 PM
white90rexsi
Jan 2, 2007 07:55 PM
ekb16
Sep 27, 2005 08:12 PM
bboylito
13
Apr 15, 2005 03:46 AM
