Alternator Help
Old Jul 24, 2005 | 07:51 AM
Sanyo's Avatar
Default Alternator Help
Ok, looking for some help. My friend's got a 93 Civic DX with a bad alternator. I figured NP, alternators are easy. Get over there, get the electrical connection off, get the top bolt off. The bottom bolt, however, is like a 1 inch square bolt. The other side is just threads?? WTF? Doesn't budge, can't hammer it out, and the alternator bracket bolts underneath are stripped? Anyone got any pics of what to do, any help would be much appreciated! Thanksd in advance
Old Jul 24, 2005 | 07:57 AM
Chiovnidca's Avatar
Default Re: Alternator Help (Sanyo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sanyo &raquo;</TD></TR><TR><TD CLASS="quote">The bottom bolt, however, is like a 1 inch square bolt. </TD></TR></TABLE>
Sounds like it's seized in there pretty good, I use a brass drift to beat them out when they're stuck like that.
Old Jul 24, 2005 | 02:51 PM
Sanyo's Avatar
Default Re: Alternator Help (Chiovnidca)
Wait, so how does that bottom bolt come out? Once its loose does the alternator pivot? It doesn't look like theres a nut that goes over it, just a washer. Is that big washer looking thing the nut? Thanks!
Old Jul 24, 2005 | 09:27 PM
Sanyo's Avatar
*BUMP*
There's no nut on it, so do I just wack it out? Thanks!
Old Jul 25, 2005 | 03:08 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sanyo &raquo;</TD></TR><TR><TD CLASS="quote">*BUMP*
There's no nut on it, so do I just wack it out? Thanks!</TD></TR></TABLE>
Yea, there should be a nut on it.
Old Jul 25, 2005 | 09:42 AM
Sanyo's Avatar
Ok here's some pics!
Old Jul 25, 2005 | 09:46 AM
litterbox's Avatar
I am a (Trial User) Army
Could you use a punch and punch the bolt out? From left to right on that last pic?
Old Jul 25, 2005 | 10:23 AM
spoonek9's Avatar
Remove the 12mm nut on the adjuster bracket (On top). Then remove the 14mm nut on the lower bracket and remove the belt.
To get the lower bolt out, I would take a pry bar to the square end of the bolt and pry it out as far as possible. Then I would just pivot the alternator back a forth while pulling on the pin. You could also try hitting the bottom of the alternator with a hammer to try an loosen that bolt up.
Old Jul 25, 2005 | 10:27 AM
Sanyo's Avatar
Default Re: Alternator Help (spoonek9)
I used a big chisel and a BFH, didn't budge at all. Used alot of WD-40 to
CRXB5
12
Jul 8, 2010 07:15 PM
smmcla
Mar 30, 2010 06:04 PM
Pagley
Mar 25, 2009 12:05 PM
sleepa
Jun 3, 2008 04:31 AM
GroundZer0 336
16
Mar 4, 2004 07:30 AM
