Are all honda alternators the same?
Old Jan 10, 2003 | 11:30 PM
omahaturbocivic's Avatar
Default Are all honda alternators the same?
I need to know if I can use an altnernator off a d series with a b18a motor. I know they use the same plugs and the civic is about 10 less amps. Is there any difference in the way they bolt up??????
Old Jan 10, 2003 | 11:46 PM
Kamin's Avatar
Default Re: Are all honda alternators the same? (omahaturbocivic)
no
it wont line up with the upper bracket.
Old Jan 10, 2003 | 11:48 PM
Shawn C's Avatar
In The Garage
depends which d-series youre talkin about, from a D15 to a D16Y8.... lets see..... B18A, 90-93 teg ls..... id try one off of a 92-95 civic dx (id really use one off of a B18A). just my .02
OR.... Kamin could smote me to it with a better sounding answer, while he doubles my posts. i was goin for 400 tonight, i guess he was goin for 800. gees..... oh well i can sleep now.
[Modified by 22lbGS-R, 8:50 AM 1/11/2003]
Old Jan 10, 2003 | 11:52 PM
Default Re: Are all honda alternators the same? (22lbGS-R)
Older civics at the junkyards are a dime a dozen, and an alternator would be practically free with a guarantee. If I actually have to buy one though of course ill just get the integra. Thanks for the info though!
Old Jan 11, 2003 | 10:52 AM
Flexmyrex's Avatar
ive used my crx alternator w the b18a, it works fine but the only thing is that the d alt have less teeth on the pulley, so you'll have the belt wearing out quick. but it worked fine on my car till i got a cheap b16 alternator. works good.
Old Jan 11, 2003 | 11:07 AM
Kamin's Avatar
postcount means nothing, i was over 10,000.
anyway my first hand experience is that a d series dosent fit on my b16, i tried the one off my d16z6 on my second gen b16 and it didnt work, even a del sol vtec (b16a3 engine) alternator didnt work, i had to use a GSR.
Old Jan 11, 2003 | 02:15 PM
boostinb18's Avatar
Default Re: Are all honda alternators the same? (Kamin)
YES THE D-SERIES WILL FIT.... i just put a zc single cam alternator on my LS motor.. the upper bracket holes wont line up but the lower will fine... just get creative and it works fine... and you have to use the d series belt.
Old Jan 11, 2003 | 03:01 PM
Shawn C's Avatar
In The Garage
Default Re: Are all honda alternators the same? (boostinb18)
hmm...... sounds dangerous to me, id be afraid about getting stranded in BFE when the jerry-rig goes.
Old Jan 11, 2003 | 03:02 PM
Kamin's Avatar
well then i was right
it dosent fit PROPERLY
Old Jan 12, 2003 | 07:04 PM
Flexmyrex's Avatar
worked properly on my ls
Old Jan 12, 2003 | 07:08 PM
Starrman85's Avatar
Default Re: Are all honda alternators the same? (flexmyREX)
working right, and fitting right are two different things.
Old Jan 13, 2003 | 02:41 PM
Flexmyrex's Avatar
Default Re: Are all honda alternators the same? (STARRMAN85)
when i said worked properly, i meant it fit and worked properly.
feel stupid , you should.
juanEG
Feb 27, 2015 01:50 AM
hmtcrxsir
Jan 7, 2010 03:23 PM
WookinPaNub
Classic Hondas
Nov 6, 2007 01:55 PM
HondaCutter
Aug 9, 2003 07:17 PM
MidoriEK4
Feb 24, 2003 11:31 PM
