Heater blows cold air ??wtf ??
Old Dec 19, 2004 | 11:06 PM
93FastLs's Avatar
Default Heater blows cold air ??wtf ??
ok..it's a 92 vxC1 powered no a/c i took it out.i took all the lines out especially the ones under the battery try, everytime i put the vents or foot vents on.. if im at a light..or if im standing still it blows cold air.. but when i move( highway,street driving..etc..) it blows hot air... do i have to cap off the 2 holes on the firewall...
Old Dec 19, 2004 | 11:38 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Heater blows cold air ??wtf ?? (93FastLs)
sounds like your low on coolant , my car does that when im low on coolant.
Old Dec 20, 2004 | 01:27 AM
@ries's Avatar
Default Re: Heater blows cold air ??wtf ?? (Hella_JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">sounds like your low on coolant , my car does that when im low on coolant.</TD></TR></TABLE>yea but... your motor is also missing another cam.
Old Dec 20, 2004 | 07:58 AM
chameleon's Avatar
Default Re: Heater blows cold air ??wtf ?? (@ries)
definitely dont cap off the 2 lines on the firewall thats what circulates coolant to your heater core box so that it can blow hot air, check your coolant level and top it off and bleed it off. sometimes when you swap a motor in you have to wait until the fans turn on which is the best point to top off your coolant but also when the fans kick on you have to turn your interior fan all the way on and put it to all the way hot this way everything that is circulating when the thermostat opens also fills up your heater core with a less chance that you get air bubbles in the system.
Old Dec 20, 2004 | 10:38 AM
93FastLs's Avatar
ok i topped off my coolant.. bleed the system and it still blows cold air..the only i questions are those 2 holes that are open under the battery box ? if i cover them.. i feel air being sucked into the car...is that a reason for the cold air while im sitting still..
Old Dec 20, 2004 | 02:03 PM
MugenRacerX's Avatar
maybe your thermostat is stuck open,not alowwing the coolant to reach the proper temp.
Wrona
Nov 6, 2011 02:26 PM
wicked_b16eg
Dec 30, 2007 09:57 AM
bigizsosexy
May 14, 2006 07:34 PM
teler86
Apr 7, 2006 04:43 AM
cloven
Feb 18, 2006 07:06 PM
