AEM wide band question
Old Jun 23, 2006 | 08:58 PM
NitrousB.I.G.'s Avatar
Default AEM wide band question
I just got a aem gauge type wide band and want to install it. Do I need to disengauge the o2 heater to avoid a cell. And do I need to switch the gauge to p4 to switch the out put to 1v. And which wire do I plug into the ECU.
Old Jun 23, 2006 | 09:07 PM
SuzukaBlueAP2's Avatar
Default Re: AEM wide band question (NitrousB.I.G.)
What car are you putting this in?
Do you have the AEM EMS or some other stand-along engine management system?
Old Jun 23, 2006 | 09:31 PM
98vtec's Avatar
moderator emeritus
you need to install an o2 bung before the cat and then screw the o2 into it.
Old Aug 14, 2006 | 07:40 PM
Default Re: AEM wide band question (98vtec)
I am running the stock p72 JDM ecu and I am now running the AEM wide band on setting p4 to simulate the output of a narrow band (0-1v) to the ecu. Everything is woking great but I am getting a cell for O2 sensor heater. What I want to do is put in a resistor (or what ever works) to simulate the heater and get rid of the cell to go through emitions. This will be a temporary measure until I get my ecu chipped and turn off the O2 heater.
Old Aug 15, 2006 | 06:27 AM
Natural Aspirations's Avatar
10 watt 10 ohm works, its a big white creamic resistor that can be found at raido shack
Josh B. Bryant
Mar 29, 2018 05:11 AM
Tims Toy 500
18
Oct 6, 2013 02:04 PM
DC2-ProdUcTiOnS
May 13, 2009 07:00 PM
JDMorgan
Apr 4, 2005 11:05 AM
BoostedSi
Mar 23, 2003 09:13 AM
