Advantages of going from OBDII-OBDI?
Old Sep 23, 2002 | 10:42 AM
Bleed Black's Avatar
Default Advantages of going from OBDII-OBDI?
What are some of the advantages of switching to OBDI other than one O2 sensor and the capability of chipping? Im running a 99 EX ecu with my minie-me setup (complete 99 EX wiring harness), and right now Im throwing a secondary O2 sensor code because its not even hooked up(no bunge and no cat). Would it even be worth it for me to convert to OBDI with a P28 or should I just get an O2 simulator wired n to "trick" the ECU? I can see the advantages of OBDI for B-series because of the chipping capabilities but I havent seen many progroms for SOHC. I do plan on Running a Zex kit for a while until I save up for boost. Thanks
Old Sep 23, 2002 | 01:43 PM
Spade's Avatar
Default Re: Advantages of going from OBDII-OBDI? (slowasshatch)
Chipping is the reason.
All ECU's act the same way. Just add fuel and VTEC crossover at different points.
What is easier for you to do, add an O2 simulator or re-wire everything?
Sphorti1
Mar 1, 2016 04:54 PM
lazii_boi08
Nov 11, 2008 05:45 PM
parasonic
May 29, 2007 04:35 AM
kyden
Sep 28, 2004 04:18 PM
dstring20
Jun 2, 2004 05:08 PM
