Adjustable rocker arms
Old Oct 8, 2008 | 05:02 AM
CR3X's Avatar
Default Adjustable rocker arms
I did some searching but came up with nothing. Do any Hondas have adjustable rocker arms? If not is there anywhere I can get some? The reason being for custom camshaft design.
Old Oct 8, 2008 | 06:44 AM
GhostAccord's Avatar
Default Re: Adjustable rocker arms (CR3X)
I'm not sure if I follow what it is that your looking for but there are quite a few Honda engines that have rockers with adjusting screws on them. I know that the F22 and H22 have them for sure. They are used to adjust the valve to rocker clearances.
I don't see why you need adjustable rockers for a custom cam design? There are quite a few people running custom ground or hard welded cams in Honda engines. I think most would suggest using completely upgraded rocker assemblies to handle the higher lift & RPMs though.
hondah2b21
Apr 25, 2010 01:40 PM
carlitosway12345678
Oct 3, 2008 09:55 PM
hulk_22
Jan 9, 2007 08:55 PM
NewOrleansH22
May 7, 2005 09:36 AM
Rick Solis
Oct 26, 2004 11:09 AM
