Adding interior lights
Old Jul 20, 2013 | 09:31 PM
hardrock2401's Avatar
Icon2 Adding interior lights
I have a 97 ex and it has absolutely no lights that come on at night when the door opens. I dont have a dome light either, it really bothers me as I do a lot of night driving and all my other cars have had something.
What would be the easiest thing for me to wire into so I could run a strip of white leds on each footwell that will light when the door is opened.
Old Jul 20, 2013 | 09:44 PM
silkypillows's Avatar
Default Re: Adding interior lights
is the dome light there?
if the stock stereo is removed, the dome light is disabled. if the light is still there, two wires can be connected in the stock stereo harness to make the dome light work.
one wire is the door switches, and the other is the dome-light wire. i believe it's green/black and green/red. should be quite a few threads on it.
the door switch wire can also be used as the ground for additional led's
Old Jul 20, 2013 | 09:47 PM
slowDB7's Avatar
you can wire them to your door jam switch, or figure out what is wrong with your dome light
Old Jul 20, 2013 | 09:52 PM
The car is just not equipped with a dome light, its not that it doesnt work...just doesnt have one
Old Jul 20, 2013 | 10:03 PM
97 civic ex? usdm?
whatever the model, if it has switches in the door jamb, the single wire behind the interior panels of the b-pillar and c-pillar in sedans, can be used for the ground of an led.
Old Jul 20, 2013 | 10:05 PM
slowDB7's Avatar
i bet if you removed the headliner, the wire harness for it and dome light mount holes are there. sounds like the previous owner removed it cuz all civics had dome lights in 97
Old Jul 20, 2013 | 10:26 PM
Idk why they would of, idk how the dome lights attach in these cars but theres no hole or anything modified to the headliner. Car is 100% stock, not one thing modified.
So just run the power of the led to a constant source and ground it with the door jam switch?
Old Jul 20, 2013 | 10:49 PM
slowDB7's Avatar
yes
Old Jul 22, 2013 | 05:51 AM
kyden's Avatar
there's supposed to a dome light oem. all civics came with them.
Old Jul 22, 2013 | 08:04 AM
Mr. Bojangles's Avatar
Don't all 6th Gen EXs have map lights too?
Old Jul 22, 2013 | 08:18 AM
spAdam's Avatar
Loved
Community Favorite
Yeah EX should have both.
Old Jul 22, 2013 | 11:24 AM
So then you could wire those up to the door switch.
Old Jul 22, 2013 | 11:46 AM
spAdam's Avatar
Loved
Community Favorite
Surely. But someone has reupholstered the OP's headliner or something. He's probably nothing more than a razor blade away from popping some junkyard lights back in there.
I can't think of any non-convertible car made in the last 50 years not coming with a dome light!
Old Jul 22, 2013 | 11:51 AM
fcm's Avatar
fcm
Old Fart
97 2 door EX...
Attachment 330228
Pretty much the same as below.
97 4door EX...
If they are not there someone removed them and redid the headliner. 94
Old Jul 22, 2013 | 01:04 PM
it can be done, but the map lights use a positive switch - chassis ground would need to be removed and switched, or the constant 12v wire has to be switched with a relay.
you would lose functionality of the map light switch unless you wired the relay to bypass the switch.
my civic is wired the first way, it's nice to get some light up front.
DCiFound
Lighting
Jul 13, 2014 07:57 PM
dale m.
Jan 4, 2010 01:30 PM
adhuot01
May 14, 2008 09:55 AM
civicmark
Audio / Security / Video
Jan 2, 2003 11:31 AM
gsr squirrel
Sep 22, 2001 04:39 PM
