About to take type r to junkyard!!! Won't start! Solid CEL!
Old May 23, 2012 | 09:21 PM
  #26
turbohatch96y7's Avatar
Default Re: About to take type r to junkyard!!! Won't start! Solid CEL!
okay i attached a really big pic of the schematic for a 93 si p28
the yellow lines are your 12 volt input for your ecu.. if you are getting 3 volts at the relay than most likely you have a bad connection at the fuse box or the fuse has developed internal resistance..
breakdow of whats happening in the pic...
batter volts comes in at fuse 31 in the under hood fuse box supplies voltage to the relay tips when the key is turned to the on position..
Old May 25, 2012 | 08:07 PM
  #27
WideBodyTypeR's Avatar
Originally Posted by a1320addict
I apologize, I was referencing off a DC2 chassis, misread your original post..thought it was in an ITR.
Either way, can you post a picture of the melted fuse? If I'm understanding your correctly, that would be your Radiator Fan. If it is MELTED, as opposed to blown, remove it and see where you get. It's not really great to have a melted fusible link still in place, lol.
No, radiator fan is fuse 33, the one that melted is right next to it witch says its rear defrost... If you stand on passenger sure of car and look at fuse box, the fuse that melted is the one towards the firewall and towards the driver side...
|***1|
|*~+ |. Let's say that's the fuse box if looking from the front of car, the fuse where the 1 is, is the fuse that melted. Sorry I'm new member, unsure how to post pics lol. And yes it's melted... And blown actually haha. I'm gonna replace fuse of soon anyway.
Old May 25, 2012 | 08:13 PM
  #28
Originally Posted by fcm
Your misunderstanding how the PGM-FI Main Relay works and what it does.
The PGM-FI Main Relay, as you say, has two(2) relays in it, one is the fuel injector relay the other is the fuel pump relay, when you turn your ign. switch to the run position, this will happen, [or should happen] the ign switch will supply the PGM-FI Main Relay power, [12.5V or whatever batt. voltage is] that power goes to the fuel injector relays coil, [other side of coil is grounded] it also supplies power to the input, #30 of the fuel pump relay, this lead is almost always a yellow/black.
When that power is supplied to the PGM-FI main Relay there will be two(2) "clicks" from the PGM-FI Main Relay, first click is the fuel injector relay turning on and the second click is the fuel pump relay turning on, these "clicks" are very close together so they can sound/feel like one click.
At the same time, [when you turn on the ign. switch] the cluster will light up, including the CEL, the fuel pump will start priming.
After no more then a few sec. there will be a third click from the PGM-FI Main Relay, fuel pump relay turning off, at the same time the CEL will go out.
If any of the above is not happening the engine will not start, and the problem is related to the PGM-FI Main Relay, it may not be the relay itself, but related to it.
The fuel injector relay, [when on] supplies power to the fuel injectors, [obviously] internally to the fuel pump relays coil, to a few engine valve/solenoids and heated O2 sensor if you have one, last but not least and very important to IGP1 and IGP2 at ECU/ECM, both IGP1 and 2 must have batt. voltage on them or not much of anything will happen, ECU/ECM will not supply the ground for the fuel pump relays coil, ECU/ECM will not pulse the injectors, just to name two things.
The first things you should test for is...
1- Injector relays coil ground, [black] is a good groung, [full continuity to chassis ground]
2- the PGM-FI Main Relay has all three(3) of it's powers, unplug the relay and test for batt. voltage
There must be a 12V constant lead, [hot at all times] normally yellow/white, whatever the color there is only one 12V constant and it must be batt. voltage, it is the input, #30 to the injector relay.
There must be a 12V switched lead, [hot in run AND start] normally yellow/black, again fuel injector relays coil and input, [#30] to the fuel pump relay.
There must be a second 12V switched lead, [hot only when cranking to start] normally blue/white
The colors of the lead may differ from model to model/year to year but not what they are and when they are hot.
You need to confirm 12V+, [batt. voltage] at IGP1 and IGP2 when ign. switch is in run AND start.
If any of the above is not right engine will not start.
Check what I have suggested and let me know what you find. 94
I already did all those checks. That's how I found that the igp1 and igp2 only hat 2 volts instead of battery voltage. I tried running new wire from main relay to Ecu, but it didn't work, so I just wired to the battery. For now at least. I just bought a whole new harness for under the dash including Ecu harness. I'm gonna try to find out what's the problem before taking my whole dash out and just replacing the whole thing. (really hope I don't have to)
Old May 25, 2012 | 08:18 PM
  #29
Thank you!!!!!! This will be very helpful!! I will check that circuit as soon as possible!!! Thank you guys all for the input, hands down, HONDA-TECH Is the best place for advice when it comes to Hondas! I'm a member of other websites and I won say James but not many replied with help, and those who did told me to charge my battery or something like that lol. HONDA-TECH ALL DAY!!!!
Old May 26, 2012 | 02:25 PM
  #30
WEIRDEST THING JUST HAPPENED, my car starts just fine now. I originally hooked up a switch when I realized Ecu didn't have power, but Now it turns on even without the switch.... I don't know why happened now it's working just fine witch makes it harder to figure out because that means its gonna happen at any random moment. Ill post more details later
Old May 28, 2012 | 12:55 AM
  #31
g230sport's Avatar
Have you replaced that fuse yet? And any chance the ignition switch is bad?
Old May 29, 2012 | 04:36 PM
  #32
The rear defrost fuse??? I shoved another one in there but the thing isted and I don't think it is actually making contact.. I'm gonna replace the fuse box soon but so far I'm really confused because now its working just fine. And I have not replaced the ignition switch, because I have push start in my car.. But At this point I'm kinda of at a point where I cant do anything else until it happens again because the car is working now
pyroom
12
Apr 6, 2025 10:42 AM
boarding2008
Jun 2, 2022 01:08 PM
JShull
61
Oct 12, 2017 09:42 AM
joann1874
May 30, 2010 01:51 PM
lonefuzzy79
Dec 16, 2003 12:37 PM
