96 JDM B16 into 99 Ex. OBD2a JDM Distributor wirring -> OBD2b US harness
Old 08-15-2005, 06:07 PM
2 0 3's Avatar
Default 96 JDM B16 into 99 Ex. OBD2a JDM Distributor wirring -> OBD2b US harness
trying to wire up a 96 JDM B16 into a 99 civic EX...
JDM dizzy has 9 wires... US has 8... i can just color match i supose. but that will leave me with one extra wire ?
also... i was considering the diffent number of wires maybe having to do with the fact that there is no CKF sensor on the JDM motors... maybe it picks up some sort of signal from the Dizzy ?
if not. whats the easiest fix for this no CKF issue? id rather not have to replace the oil pump, buy a sensor, and replace the timming belt gear
Old 08-15-2005, 07:01 PM
2 0 3's Avatar
Default Re: 96 JDM B16 into 99 Ex. OBD2a JDM Distributor wirring -> OBD2b US harness (EallmotorF)
help
Old 08-15-2005, 07:36 PM
FyReo3's Avatar
You will have one blue wire that does not match, just terminate it. It is the Tach signal wire.
Old 08-15-2005, 08:19 PM
2 0 3's Avatar
Default Re: 96 JDM B16 into 99 Ex. OBD2a JDM Distributor wirring -> OBD2b US harness (FyReo3)
what i though.. ok cool
any insight on this friggan ckf sensor... i need to run a us ecu. so its ogna look for it. theres got to be a way around this ****. maybe not. i dono
strider380
11-12-2010 08:53 PM
boostcrazy721
05-26-2007 10:26 AM
D15JDMARIO
03-06-2007 04:41 PM
B16 IIgen
10-30-2006 06:09 AM
2 0 3
08-16-2005 08:05 PM
Quick Reply: 96 JDM B16 into 99 Ex. OBD2a JDM Distributor wirring -> OBD2b US harness
