96 Honda Accord EX not staying up to temp in cold Wisconsin winter
Old 02-16-2019, 07:39 AM
Mike Rongo's Avatar
Default 96 Honda Accord EX not staying up to temp in cold Wisconsin winter
Not super familiar on this topic, hence the post. But we are constantly below 15 degrees Fahrenheit up here for most of the winter and my car doesnt seem to stay up to temp. The temperature gauge will get up there if you let it warm up in park for 10 minutes and keep it on a very specific heat setting, but occasionally will dip down to a lower than normal temp...unfortunately this heat setting prevents me from keeping my windows de-frosted or the passengers in the car warm (really annoying)....can this be a thermostat issue?...If it is a thermostat stuck open, wouldnt the temperature gauge not even move upward? I was told by a buddy that this is common on older cars in the winter to get cold when in drive. Just super inconvenient for the time of year when we're getting slammed with cold weather day by day, and it seems super fixable. Any insight?
EDIT: Worth noting i had the water pump and timing belt just replaced less than 2 years ago...FWIW. I understand that a faulty water pump can cause the car to overheat, but this is the exact opposite?
Old 02-16-2019, 08:06 AM
3D Stuff's Avatar
Default Re: 96 Honda Accord EX not staying up to temp in cold Wisconsin winter
Hi Mike, This could certainly be caused by a sticking thermostat. If I understand your post correctly, the vehicle will warm up ok when parked but while driving the temp drops. This is due to the increased airflow across the radiator. A quick (temporary) solution would be to block part of your radiator to reduce air flow during driving. Semi truck drivers will often use this method to maintain proper operating temperatures in very cold climates.
Old 02-16-2019, 08:08 AM
Mike Rongo's Avatar
Hi I really appreciate it....That definitely gives me a starting point before I start ripping apart the radiator in freezing temps ...Hopefully its as simple as this $20 fix.
Old 02-16-2019, 09:09 AM
shipo's Avatar
Stuck thermostats are not at all uncommon.
smeltjr
09-17-2010 05:28 PM
khronicboy420
12-18-2008 06:22 AM
erik92DA
10-23-2005 12:32 PM
kruthles
07-31-2005 09:29 AM
Quick Reply: 96 Honda Accord EX not staying up to temp in cold Wisconsin winter
