95 Civic Speedo Trouble!
Old Jan 10, 2010 | 08:31 PM
95HondaCivicGrl's Avatar
Default 95 Civic Speedo Trouble!
Ok, I have a 95 Honda Civic EX and the spedoeter stoppped working and I have no idea how to fix it. I've replaced the gauge cluster and nothing happened. (Mind you, it's only the MPH gauge that doesn't work.) I have also replaced the VSS (Vehicle Speed Sensor) and it still did nothing. It use to bounce around when it first started happening and I would be going 20 MPH and it would jump to 100 MPH. But now it just stays at a dead 0 MPH. I don't know what else to do. Can anyone help, or have any suggestions??
Old Jan 10, 2010 | 09:15 PM
88Hatchy's Avatar
Default Re: 95 Civic Speedo Trouble!
Sounds like a wiring issue.
1. Check for continuity between the cluster and the VSS.
2. Check for 12v power at the VSS.
3. Check the to make sure the ground wire at the VSS has a good connection.
Old Jan 11, 2010 | 07:37 AM
Thank you, I will have to try those. Your the only freaking person trying to help. Lol. Thanks.
ttt
Old Jan 11, 2010 | 08:29 AM
SpoonSportsDC4's Avatar
my boi had a hatch wiff the same problem and he had a bad speedo cable gear in the tranny, u can try replace the speedo cable too since thats the only thing that dosent work on the cluster sounds like it could be the cause.
Old Jan 11, 2010 | 05:41 PM
are you talking about the speed sensor or the gear that spends the sensor inside the tranny?
ttt
Old Jan 12, 2010 | 07:32 AM
ttt
j390s
Dec 5, 2009 09:47 PM
RTE117
Apr 22, 2009 09:52 AM
JDM Dylan
14
Mar 5, 2008 09:11 PM
joethejoeman
Jan 18, 2007 04:50 PM
kamakaze1
Oct 27, 2006 06:31 AM
