94-up LS cams in 90
You don't need any mods, ya just put 'em in. Should get you 140 hp like the 92-93 b18a.
edit: As far as I know, 92-93 cams are the same as 94+. It's just the 90-91 that got the shaft.
[Modified by robbin, 4:20 AM 9/26/2002]
You probably won't get 140HP. The 1990-1991 ECU does not give you enough fuel for this. And adjustable FPR will help but will cause richness in the lower RPMs.
