94 accord gears wont engage
Old 03-22-2012, 02:45 PM
cezium's Avatar
Default 94 accord gears wont engage
I was driving then all the sudden it just wouldnt go into gear anymore, it was like it was permanently in neutral, there was a feint burning smell too.
Clutch peddal has pressure, will shift into any gear though without it. Car will not turn on without clutch pushed in, car does not learch even a tiny bit if i start it in first gear.
Hoping i wont have to drop the tranny, and there might be a simpler fix, so if anyone can think of anything else let me know.
recently replaced the master cylinder, although i did not adjust it perfectly, there was a feel of a little bit of extra space before it felt like it was engaging the clutch, not sure if maybe that caused the problem.
Old 03-23-2012, 07:24 AM
fcm
Old Fart
fcm's Avatar
Default Re: 94 accord gears wont engage
Check the slave cylinder push rod for movement, make sure it moves back all the way to take any pressure off the clutch release lever. 94
94ej1coupe206
12-20-2016 07:45 AM
zothorn
05-12-2016 11:53 PM
DOHC4banger
06-08-2009 07:52 PM
codybb4
12-09-2008 08:44 AM
Quick Reply: 94 accord gears wont engage
