93 Ex EJ1 Wont Start!
Old Dec 22, 2012 | 10:50 AM
  #26
montero23's Avatar
Default Re: 93 Ex EJ1 Wont Start!
Originally Posted by fcm
If your smelling something burning, you have either a short or a connection problem.
When exactly do you smell the "burning" when key is turned on to acc, run or all the way to start? 94
Yeah when I'm trying to start the car, I turn the key fast and the burning smell comes up, I checked all my fuses and non are bad
Old Dec 22, 2012 | 10:59 AM
  #27
grumblemarc's Avatar
The Grumpiest
The burning smell is coming from inside the car or from under the hood? You really need to track this mess down.
Old Dec 22, 2012 | 11:03 AM
  #28
montero23's Avatar
Frm the inside, while I'm trying to turn on the car, the problem is inside not under the hood
Old Dec 22, 2012 | 02:28 PM
  #29
montero23's Avatar
yeah thats what im thinking, im having a an electrician come and check the car on tuesday, hopefully he finds the problem
Old Dec 23, 2012 | 10:08 AM
  #30
fcm's Avatar
fcm
Old Fart
Not exactly what I asked.
Is the burning smell there only when trying to start the engine, [ign. key in the start position] or is it there also when the key is in the acc. or run position?
To narrow down the circuit that is "burning" I need to know when exactly you get the burning smell, if it only happens when trying to start the engine, [cranking] it narrows it down quit a bit, it can only be the ign. switch itself, starter contacts in the switch burning] or the starter lead to the starter relay, the starter relay itself or the lead from the starter relay to the starter solenoid, or any connection point in between.
There is no fuse between the ign. switch and the starter solenoid to blow, so you would not find a blown fuse. 94
electron_si
Feb 10, 2011 05:47 PM
wintermute
Feb 12, 2007 12:09 PM
QUICKERSILV3R
Apr 7, 2006 08:59 PM
bleedblue94
11
Aug 27, 2004 07:05 AM
Black93EG
Apr 25, 2004 09:24 PM
