93 civic ex
Old May 30, 2009 | 01:14 PM
Necro86's Avatar
New User
Default 93 civic ex
can i convert my 93 civic ex from an automatic to a 5 speed.
Old May 30, 2009 | 01:38 PM
RanCRX's Avatar
Default Re: 93 civic ex
Yes you can, you have to buy the shift linkages for your car, as well as the pedal assembly. Then you would have to buy the manual transmission and clutch kit.
After getting passed that task, you have to mess with the park switch thing, so you can be able to start your car. I believe its located underneath the carpet next to the stick you use to change gears. I kinda forget.
But it is a little pain but it can be done. You may have to drill your own screw holes for your manual stick to mount.
I also forgot to mention, I believe the automatic transmission mount bracket hooked up to the frame is raised up higher, than a manual transmission mountframe would be. Meaning I know that part is different between a honda civic car made factory automatic, and honda civic made with manual transmission from factory.
The thing was, was that we did a b16 swap into a 4 door eg civic, so maybe it was because the engine was bigger. Might have no effect just switching transmissions on a SOHC,
Good luck
Old May 31, 2009 | 11:48 AM
Necro86's Avatar
New User
thank you i thought i could i just wanted to make sure before i go buy tranny and all of that.It has the 1.6 vtec though so if i pull a tranny out of a 93 ex like mine but a 5 speed it should all match up pretty close.
Ej1d16y8
Aug 21, 2018 04:43 PM
almostlover000
Aug 28, 2016 04:25 AM
civicguy395
Nov 26, 2012 04:11 PM
1swtcvic9030
Jan 25, 2008 07:40 AM
Blackdogz
Oct 8, 2007 02:12 PM
