92 Hatch H22 swap questions....
When driving drivers side feels like the wheel is going to fall off or as if i have a flat? Its also making some kind of popping noise? I have HCP motor mounts any suggestions on what could be causing this problem?
Drive side axle doesnt look right? How do i fix that?
You're axles are probably going bad. how low are you dropped? what axles are you using? Is your engine aligned right in the bay? Are the mounts torqued right? When did you drop in the engine?
How low are you dropped? Pictures help out a lot as well. I cannot provide you with the information that you need but these guys here will help you out a lot!
https://honda-tech.com/zerothread?id=350953
Poison, Jason Kidd, JDMxTurd as well as some others there are very knowledgable on h22 swaps and are more than helpful to help you out. Wish you luck!
N/M we thought we had it....turns out the guy i bought the swap from didnt give me the right axles or something? Its a 98 intermediate shaft and we have 94 axles?? Will this work or will we have to buy the 88 intregra axles?
DRoszyk
Oct 26, 2010 02:42 PM
slp mode
Apr 20, 2007 08:42 AM
