9.3:1 Compression good for FI
Old Apr 27, 2005 | 12:45 AM
pcguy760's Avatar
Default 9.3:1 or 8.5:1 Compression good for FI ??
Hi I am wondering if 9.3:1 Compression is good for a turbo or supercharger setup or should I go with 8.5:1 ? What are the differences.
Using ROSS Pistons by the way . Heard alot of good things about them.
Old Apr 27, 2005 | 09:11 AM
PrettyLude's Avatar
9.3-1 would be good, 8.5-1 is too long imo
Old Apr 27, 2005 | 09:31 AM
pcguy760's Avatar
Default Re: 9.3:1 or 8.5:1 Compression good for FI ?? (pcguy760)
Thanks Lude - I was thinking that 9.3:1 would be better - so that's what I will use. Anyone else think's the same?
Old Apr 27, 2005 | 09:46 AM
tgreaves's Avatar
I would say that 9.3:1 is still a little low for anything.. 8.5:1 is just crazy..
Old Apr 27, 2005 | 09:58 AM
pcguy760's Avatar
Default Re: 9.3:1 or 8.5:1 Compression good for FI ?? (tgreaves)
What would be an ideal compression ratio then for about 10 to 15 PSI of boost ? Remember this is a B18C1 .020 overbore. Thanks.
Old Apr 27, 2005 | 10:00 AM
tgreaves's Avatar
9.5:1 to 9.8:1 is perfect.. Why 10psi or 15psi??? Why not 100psi or 2psi.... Aim for a HP goal and run whatever psi it takes to get to that goal..
Old Apr 27, 2005 | 09:13 PM
zacdaddy77's Avatar
you are getting the block sleeved right?
Old Apr 28, 2005 | 12:04 AM
pcguy760's Avatar
Ok but will 9.3:1 work well? The Ross pistons/rings I am getting are 9.3:1. I was told that I do not have to sleeve the block as I am not running really high boost at all.
BTW tgreaves do you still have that MSD SCI for sale? If so, I am interested but since I am a newbie I can't IM you are anything - so can you email me at : fastcivic@insightbb.com
Thanks.
Old Apr 28, 2005 | 05:35 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pcguy760 &raquo;</TD></TR><TR><TD CLASS="quote">BTW tgreaves do you still have that MSD SCI for sale? If so, I am interested but since I am a newbie I can't IM you are anything - so can you email me at : fastcivic@insightbb.com
Thanks.</TD></TR></TABLE>
You have email..
Old Apr 29, 2005 | 07:43 AM
95accordsir-t's Avatar
ive heard gsr blocks could hold decent boost. and ive seen a tech article saying that it is common to see boosted engines with compression ratios up 11.0-1 easy. but this would not be a good ideal for daily driving cause u probably would most definately be using racing fuel to help prevent detonation with such large amouts of compressed air inside of the cylinder. i am about to start building a b20/VTEC bored stroked sleeved and everything with a 10.5-1 compression ratio and high boost from a t3/4 turbo and plan on putting well over 600-700 to the wheels.
happy tunning
traction sux in hondas!!!!!!!
Old May 1, 2005 | 02:18 PM
pcguy760's Avatar
Default Re: 9.3:1 or 8.5:1 Compression good for FI ?? (95accordsir-t)
Traction?? If you plan on puttin out that much power have you thought about LSD
Old May 1, 2005 | 05:21 PM
Slow ass EF's Avatar
l<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pcguy760 &raquo;</TD></TR><TR><TD CLASS="quote">Traction?? If you plan on puttin out that much power have you
thought about LSD </TD></TR></TABLE>
or a spool?
jakescivicsi
Feb 25, 2014 07:19 AM
HarfordCTR
Dec 21, 2007 07:06 PM
GSRerrr
Apr 4, 2005 07:11 PM
RA062424
Oct 20, 2004 10:46 AM
s0liDyNe
Jul 19, 2003 10:24 PM
