4 wheeel disc conversion
Old Jul 6, 2003 | 11:16 AM
b16hybridsol's Avatar
Default 4 wheeel disc conversion
i have a 90 hatch si and i took the rear disc off of a 93 integra and now i have replaced eveything but the calipers bleed the lines many times no leaks and whenever i bleed the brakes the peddel gets stiff and then when u start the car all the pressure is gone
Old Jul 6, 2003 | 12:20 PM
RHD_BB4T's Avatar
Default Re: 4 wheeel disc conversion (b16hybridsol)
This might be of some help to explain what you just said:
http://www.cliffsnotes.com/pro...=5280
Good luck though!
Dan P.
Old Jul 6, 2003 | 06:08 PM
Default Re: 4 wheeel disc conversion (Dan_P)
i said that i put a four wheel disc conversion on my 90 civic hatch and whenever i bleed the brakes i get some pressure in the pedal but then when i start the car all the pressure goes away and there are no brakes
Old Jul 6, 2003 | 10:06 PM
salbaje's Avatar
did you replace the booster as well?? what kind of bleeding did you do??
Old Jul 6, 2003 | 11:39 PM
Default Re: 4 wheeel disc conversion (salbaje)
i bled from the beeder screws and the master clinder and ya i did replace the power brake unit
philosofy1
20
Aug 4, 2010 06:57 PM
kurvy
Honda Civic (2001 - 2005)
Sep 25, 2007 03:53 PM
JDM_SOHC
21
Dec 11, 2006 09:12 AM
b16hybridsol
Jul 6, 2003 11:40 PM
