which 2nd gear will work in my ys1 lsd?
Old Dec 23, 2004 | 02:00 PM
biggdogg's Avatar
Default which 2nd gear will work in my ys1 lsd?
need to know which are interchangeable for my tranny ? puuled my case apart to swap in a ls 5th gear and saw the damage.
Old Dec 23, 2004 | 02:19 PM
notstock93's Avatar
Default Re: which 2nd gear will work in my ys1 lsd? (biggdogg)
Any b-series should work. Unless Im sorely mistaken.
Old Dec 23, 2004 | 05:20 PM
86si's Avatar
Default Re: which 2nd gear will work in my ys1 lsd? (notstock93)
92 gsr
Old Dec 24, 2004 | 02:05 PM
biggdogg's Avatar
Default Re: which 2nd gear will work in my ys1 lsd? (86si)
just wondering if the ratios were the same for the ls 2nd gear and the ys1 were the same . i could just pull it out since i have the ls tranny already pulled apart. i have another cable tranny but its in my car now ,so i would have to drop it and pull the 2nd gear outta it to replace the other .
Old Dec 24, 2004 | 07:02 PM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biggdogg &raquo;</TD></TR><TR><TD CLASS="quote">just wondering if the ratios were the same for the ls 2nd gear and the ys1 were the same . i could just pull it out since i have the ls tranny already pulled apart. i have another cable tranny but its in my car now ,so i would have to drop it and pull the 2nd gear outta it to replace the other . </TD></TR></TABLE>
for you to change the 2nd gear, you'll need to change the mainshaft. 1/2 gears are build into the mainshsft, you can't take these off the mainshaft!
Old Dec 24, 2004 | 10:11 PM
turbohonda's Avatar
Default Re: which 2nd gear will work in my ys1 lsd? (smokey2.0)
If the YS1 is an LS then you could use the mainshaft from a LS or GSR hydro tranny and if it is a YS1 Gsr tranny then you can use the mainshaft from a USDM type R or hydro B16 tranny.
Old Dec 25, 2004 | 01:16 AM
grntrex's Avatar
the YS1(92-93 USDM GSR [B17] or JDM integra XSi) is the only CABLE tranny with gears you can swap directally into a hydro case. i know this for a fact, because i have YS1 gears in a hydro case, mated to my b16a2 in my car right now.
i would assume the reverse is correct.
you'd have to use the 2nd gear from a hydro tranny
Old Dec 25, 2004 | 01:24 PM
turbohonda's Avatar
Default Re: which 2nd gear will work in my ys1 lsd? (grntrex)
The 92-93 LS cable tranny has the same first and second gear ratio as the USDM LS and Gsr hydro trannies. The 92-93 GSR is the same as a B16 first and second.
Old Dec 25, 2004 | 03:10 PM
biggdogg's Avatar
Default Re: which 2nd gear will work in my ys1 lsd? (turbohonda)
my tranny is a jdm ys1 with lsd . pulled it apart to swap in my ls 5th gear and found the 2nd gear messed up . if i can use the usdm 90 ls 2nd gear i have outta the same tranny i pulled the 5th out of it will make my job easier .
Old Dec 25, 2004 | 03:34 PM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biggdogg &raquo;</TD></TR><TR><TD CLASS="quote">my tranny is a jdm ys1 with lsd . pulled it apart to swap in my ls 5th gear and found the 2nd gear messed up . if i can use the usdm 90 ls 2nd gear i have outta the same tranny i pulled the 5th out of it will make my job easier . </TD></TR></TABLE>
why would you want to do that, the car would loose its quickness in 1 and 2 gear! i can understand changing the 5th gear, i have done that on my ys1. but changing 1 & 2, instead of buying the parts to fix the problem would be the wise decision
Old Dec 25, 2004 | 07:29 PM
biggdogg's Avatar
jusr trying to get out any easier if i can . the only other spare i have is in my car now and i`ll have to drop my tranny now to get it out . i was hoping to get this over and done with so i can just drop the ys1 in and drive it to atlanta for a couple of weeks . im waiting till i get back to drop my new poormans in so i can tune it and not waste all that gas driving back and forth to atl. 12.5-1 comp poormans with the ys1 and alot of other goodies that i dont wanna talk about right now . nothing crazy just good tuning and high comp.
Old Dec 26, 2004 | 10:11 PM
turbohonda's Avatar
The USDM 90-91 integra LS S1 trannies are different internally than the 92-2001 B-series cable/hydro trannies. The main shaft and the 2nd gear on the countershaft isn't interchangable.
Old Dec 27, 2004 | 07:42 PM
biggdogg's Avatar
problem solved .it was the reverse gear , not the 2nd gear . ls 5th gear is swapped in now and im gonna drop it in later this week . also its a y1 lsd tranny not a ys1 .my bad
Old Jan 5, 2005 | 09:19 PM
Deetz's Avatar
Crazy Honda Guy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biggdogg &raquo;</TD></TR><TR><TD CLASS="quote">problem solved .it was the reverse gear , not the 2nd gear . ls 5th gear is swapped in now and im gonna drop it in later this week . also its a y1 lsd tranny not a ys1 .my bad</TD></TR></TABLE>
Good to hear you sorted that out. There is a huge difference between the small spline Y1 tranny compared to the large spline YS1. Y1's are know for having 2nd gear problems unfortunatly.
bombDOTcom
Sep 24, 2006 10:28 PM
imptricer
Apr 28, 2006 09:04 AM
gilou bilou
Nov 11, 2005 09:05 AM
exare250
Oct 6, 2005 04:35 PM
Propulsion
Sep 26, 2005 07:32 PM
