2000 SI Tranny no reverse?Need Help
I have a 2000 si tranny.....while the car is off it won't go into 5th gear and reverse but while driving 5th can be used and reverse won't go in at all....what might be causing gears to be so hard to get into?
i was going to say a clutch issue, but you said all the other gears are ok right?
syncros must be messed up for some reason.
sorry, thats all i got...........
good luck
good luck
i dont think its syncros something else is wrong reverse doesnt have any syncros so it should go in check the linkage maybe its bent if not pull the trans and take the case off and see what you find
either your reverse synchro is dead or your reverse selector is broken or bent. i have a B hydro reverse synchro used very little. you can have it for like $10+shipping.
$75 at honda for the part. labor would be through the roof at any shop. if somebody had the tranny out of the car and handed me the tranny and the shift fork, i'd charge like $50 for the labor. but that's just good ol' me.
steveo2000em1
16
Aug 10, 2007 12:25 AM
redhbcivic
10
Aug 10, 2003 10:08 PM
Larkin W.
13
Jan 22, 2002 09:58 PM
