2 Problems! need solutions! please help!
Old Oct 16, 2008 | 08:41 PM
dc2king's Avatar
Default 2 Problems! need solutions! please help!
ok so i have a 1998 integra gsr. i recently went to get a smog check done and it failed due to the MIL (malfunction indicator lamp) being on. the guy at the shop told me to drive it around 100miles before i retest. so i drove it about 400 miles before going back and it had still not reset?? does anyone know what could be the problem? also the car is not throwing a check engine light but it still says MIL is on?
My second problem is that when i run my car at high RPMs white smoke comes out from my muffler. But when the car is idling and when im driving normal no smoke comes out? what does white smoke mean? and will this also cause my car to not pass smog?
any help would greatly be appreciated. thanks
Old Oct 16, 2008 | 10:49 PM
rd91sib18c5r's Avatar
Default Re: 2 Problems! need solutions! please help! (dc2king)
What color is the smoke? blue is oil white is coolant and black is running rich.
Old Oct 17, 2008 | 09:31 AM
dc2king's Avatar
Default Re: 2 Problems! need solutions! please help! (rd91sib18c5r)
its white smoke
Old Oct 17, 2008 | 01:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2king &raquo;</TD></TR><TR><TD CLASS="quote">its white smoke</TD></TR></TABLE>
Usually thats a sign of a blown headgasket.
Old Oct 17, 2008 | 04:53 PM
dc2king's Avatar
thats all? no more opinions??
Old Oct 19, 2008 | 06:02 PM
srmofo's Avatar
are you sure there is a good bulb in the "check engine" light socket? scan it for codes and post them up.
coolant smoke is usually a really, really thick white plume......oil is a bluish/white that is not nearly as thick they can easily be mixed up if you are not sure of what to look for....if the smoke is only at high rpms, my vote would be intake valve seals starting to go bad....i doubt its your head gasket if you are not having any other issues
Old Oct 20, 2008 | 03:02 PM
dc2king's Avatar
Default Re: 2 Problems! need solutions! please help! (srmofo)
yea we checked the bulb and its good. and when we ran it for codes it comes up with no trouble codes. but it says that the mil is on? i dont get it is the mil (malfunction indicator lamp) diffrent from the cel (check engine light)?
Old Oct 20, 2008 | 04:51 PM
srmofo's Avatar
not that Im aware of, did you try clearing it anyways.....Im thinking the guy at the smog check was an idiot
elmo908
11
Aug 1, 2007 09:06 PM
powwie
Apr 20, 2006 08:58 PM
HBK_DAVIDDD
Jul 28, 2005 11:07 PM
B00STED Si
Feb 3, 2005 10:52 AM
T_SweepeR_BB6
Dec 6, 2003 08:39 PM
