Is 1.8 CFM enough to pull vacuum on AC system
Old Jun 8, 2018 | 10:53 PM
zedjr's Avatar
Default Is 1.8 CFM enough to pull vacuum on AC system
Autozone gave me a 1.8 cfm vacuum pump adn i am wondering if this is big enough to evacuate my system. If so, how long should it be done for if system has been flushed and lines only sat open overnight.
Old Jun 9, 2018 | 07:13 AM
thisguyaves's Avatar
Default Re: Is 1.8 CFM enough to pull vacuum on AC system
I mean, 0.1 cfm is enough, it'll just take a long *** time. a 1.8 should take about 10-12 minutes (2002 civic). Use the gauge set, vaccuum from low and high side until the low end reads -20 consistently. Turn the pump off and make sure it holds -20 for 15 minutes. If it does, refill. If it doesn't, fix the leak, evacuate again, and refill.
CFM is cubic feet per minute. It's a rate, or speed. So slow still works but it'll just take longer.
Old Jun 9, 2018 | 02:21 PM
holmesnmanny's Avatar
normally you wanna evacuate for about an hour, but half hour atleast
you should also replace the receiver/drier
Old Jun 9, 2018 | 04:39 PM
Huh, @holmes my whole evac took about 15 min maybe at most, did it on a lunch break...
Old Jun 10, 2018 | 04:34 AM
15 minutes is not enough, but you're welcome to do it for however long you want to do it
Old Jun 10, 2018 | 09:00 AM
Great, now you got me worried.
Old Jun 10, 2018 | 03:55 PM
you'll be fine, it's not going to be a major issue
Old Jun 11, 2018 | 08:18 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
No
3 cfm is the minimum with 5-6 cfm being optimal.
The system should be vacuumed for 45-60 mins @ 3 cfm.
The point of vacuuming the system isn't to draw out air,it is to boil off moisture,which is the most harmful aspect of leaving the system open to atmosphere. Even at 3 cfm the pump will have a hard time boiling off all of the moisture.
Old Jun 11, 2018 | 09:20 AM
Welp, guess my 1.8 cfm job didn't work, even though I successfully charged my AC with it.
Old Jun 11, 2018 | 12:37 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Know what happens when you run pure water instead of 50/50 antifreeze mixture in your cooling system?
Nothing happens......
.......for about 5 years or so,until you begin to get multiple failures in the cooling system from the build up of oxidation, scale and cavitation.
Same deal applies here. Its fine until it isnt......
Old Jun 12, 2018 | 01:14 PM
Well I pumped until no more steam was coming out of the pump's vent and made sure it held the vacuum there at -20 hg for 15 minutes before charging. For future reference, and for the sake of any other people I try to help, when should I have stopped? (2002 civic Si)
Old Jun 12, 2018 | 03:16 PM
1 hour
Old Jun 12, 2018 | 03:50 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Originally Posted by holmesnmanny
1 hour
Agreed.
The common school of thought is, 'the longer the better' but 45-60 mins is the accepted industry standard(@ 3cfm)
Old Jun 12, 2018 | 04:19 PM
Noted. I'll go capture and re-vacuum, thanks for the info.
NIKADEM0
Honda CR-V & Element
Jul 22, 2013 10:59 AM
slockm
Jun 21, 2008 04:24 PM
92'si
Jun 26, 2007 07:03 AM
LoneStarCRX
13
Apr 18, 2006 08:10 AM
littledan
Mar 18, 2005 03:10 PM
