Suspension & Brakes Theory, alignment, spring rates....
when using xdrilled rotors....
Old 07-01-2008, 12:39 PM
TRD MA70's Avatar
Default when using xdrilled rotors....
oem pads will work just fine right. Carbon material pads arent neccesary?
Old 07-01-2008, 02:06 PM
Pirate General...YARRRR
Ass$nyper's Avatar
Default Re: when using xdrilled rotors.... (TRD MA70)
Better not to use X drilled rotors, and you could run an OEM pad but a good pad will do way more then some rotors esp X drilled.
Old 07-01-2008, 05:08 PM
TRD MA70's Avatar
Default Re: when using xdrilled rotors.... (***$nyper)
this is nonhonda related but sometimes its easier gettin answers on this forum about general stuff becuase there are so many users. What im doin is a "budget" bbk on my GS300. Supra TT calipers, stoptech xdrilled/slotted rotors, goodridge lines, and OEM toyota pads. I know some people have had experience with xdrilled/slotted cracking......and after i purchased them I thought It might be better to go with just slotted but owell, If I have any issues Ill switch that later. Im just wondering would it be better to use carbon pads instead of OEM, or does it matter that much. Its already goin to be a big improvment over the stock GS calipers (more pistons/bigger diameter)
Old 07-01-2008, 07:22 PM
BlueIntegraBoy's Avatar
You can use whatever pads you like.
mportracer33
Honda S2000
04-02-2007 09:18 AM
97civicsedan
05-12-2005 11:10 AM
the DA in HONDA
04-27-2004 09:15 PM
Trinitron
03-30-2003 09:22 PM
Quick Reply: when using xdrilled rotors....
