Suspension & Brakes Theory, alignment, spring rates....
Jdm Itr 5 lug Question
Old 12-02-2009, 07:16 PM
sikwitit's Avatar
Icon2 Jdm Itr 5 lug Question
Hey guys, so i bought some jdm itr 5 lug for a smoking deal that i couldn't pass up. The question that i have is there any way to make my stock 32mm axles work with the jdm 36mm axles and not change the hub to 32mm or change the axle with a Cr-v outer joint. I thought i saw an adapter from 32mm to 36mm but cant seem o find it. If anyone can shed some light, it would be greatly appreciated. Thanks a lot.
Old 12-02-2009, 11:18 PM
pogeeboy27's Avatar
Default Re: Jdm Itr 5 lug Question
Not sure if there is an adapter, but I would just switch out the outer hubs. It's not that hard to do.
Old 12-03-2009, 08:44 AM
94rs-turbo's Avatar
no conversion just get the axles
Old 12-03-2009, 01:05 PM
I AM WEASEL's Avatar
Another route you could go would be to use base RSX hubs
Old 12-03-2009, 01:28 PM
Ultra EK9's Avatar
Nope, The only way is to make an axle or but DSS Stage 3's and you cant convert the 36mm hub to 32mm i was gonna do that but the US ITR bearing is a little smaller and does not fit
Old 12-03-2009, 02:28 PM
sikwitit's Avatar
So what axles would fit right in? Or do i have to use my stock axles and change the outer joint to a 36mm one?
Old 12-03-2009, 03:50 PM
Base RSX hubs are 32mm and take the larger wheel bearing, so you could still use the JDM ITR knuckle. Since they are 32mm you will be able to use your current 32mm axles.
Old 12-03-2009, 04:11 PM
Ultra EK9's Avatar
i never thought of that i might do that, i had to make a couple and they dont really last that long they start to click after a while
Quickridez_3
04-21-2019 01:54 AM
Turbo R
05-01-2009 04:10 PM
ls2typer15
08-19-2008 07:07 PM
ptsaurus
03-31-2005 02:35 PM
darkknightwong
07-18-2002 02:22 PM
Quick Reply: Jdm Itr 5 lug Question
