Jdm Itr 5 lug Question
Hey guys, so i bought some jdm itr 5 lug for a smoking deal that i couldn't pass up. The question that i have is there any way to make my stock 32mm axles work with the jdm 36mm axles and not change the hub to 32mm or change the axle with a Cr-v outer joint. I thought i saw an adapter from 32mm to 36mm but cant seem o find it. If anyone can shed some light, it would be greatly appreciated. Thanks a lot.
Re: Jdm Itr 5 lug Question
Not sure if there is an adapter, but I would just switch out the outer hubs. It's not that hard to do.
no conversion just get the axles
Originally Posted by 94rs-turbo
(Post 40831589)
Nope, The only way is to make an axle or but DSS Stage 3's and you cant convert the 36mm hub to 32mm i was gonna do that but the US ITR bearing is a little smaller and does not fit
So what axles would fit right in? Or do i have to use my stock axles and change the outer joint to a 36mm one?
Base RSX hubs are 32mm and take the larger wheel bearing, so you could still use the JDM ITR knuckle. Since they are 32mm you will be able to use your current 32mm axles.
Originally Posted by I AM WEASEL
(Post 40834370)
Another route you could go would be to use base RSX hubs
