Suspension & Brakes Theory, alignment, spring rates....
Inner diameter of ground control sleeve
Old 12-16-2013, 09:48 PM
bayFERIOroan's Avatar
Default Inner diameter of ground control sleeve
Hi guys i had a thread saved or at least I thought I had it bookmarked of the difference between the koni gc sleeves and the stock gc sleeve. I've been searching for three days and have tried every possible wording configuration I can think of so I'm just gonna ask here. Believe me I've tried to not have it come down to this haha. What's the inner diameter of the koni compatible ground control sleeve? I have some gc coils here and I'm wondering if I should order some konis if they're compatible or just get something that I won't have to make work. I don't know how I'd mount the gc coils on the konis if they weren't compatible. Thanks for any help guys
Old 12-17-2013, 12:28 AM
techtuner's Avatar
Default Re: Inner diameter of ground control sleeve
approximately 1.75" where the inner sleeve sits on the clip. and the rest of the sleeve is about 1.66".
Old 12-17-2013, 06:39 AM
Sounds good thank u sir what about the tokico sleeve? Are they they same as stock ones? Reason I ask is because I never see anyone mount then on tokicos
Old 12-17-2013, 08:53 AM
techtuner's Avatar
gc sleeves for oem shocks are the same for tokico blue/illumina. To mount non koni gc on koni shocks you just need to do this https://honda-tech.com/forums/suspension-brakes-54/not-write-up-write-up-skunk2-konis-2592526/. That is what i did on my old koni/gc setup.
Old 12-17-2013, 04:47 PM
Originally Posted by techtuner
gc sleeves for oem shocks are the same for tokico blue/illumina. To mount non koni gc on koni shocks you just need to do this https://honda-tech.com/forums/showthread.php?t=2592526. That is what i did on my old koni/gc setup.
Awesome gonna look for these online and order em
Edit: nvm just saw they don't make em anymore so I'm sol, or find something similar to male em fit I guess
Nonvtak monster
Suspension & Brakes
11-26-2013 12:12 AM
monsteraddict56
Suspension & Brakes
01-30-2011 08:51 PM
Iloveyourhonda92
Suspension & Brakes
12-29-2010 10:24 PM
DEEABLO
01-19-2009 04:47 AM
steve00si
19
11-30-2004 07:37 PM
Quick Reply: Inner diameter of ground control sleeve
