Suspension & Brakes Theory, alignment, spring rates....
How To: Replace Rear Trailing Arm Bushing- Cool Tool I found Saves Allot of time
Old 04-16-2010, 05:15 AM
  #101
Trey's Avatar
Default Re: How To: Replace Rear Trailing Arm Bushing- Cool Tool I found Saves Allot of time
Originally Posted by acmoc
Are you suppose to press the old bushing out towards the wheel?
And the new bushing in towards the car
That's what I did.
Old 04-16-2010, 07:20 AM
  #102
acmoc's Avatar
Originally Posted by Trey
That's what I did.
Yea, that's the right way but the tool is not made that way is it.
I akready bought the tool too
Old 04-16-2010, 08:59 AM
  #103
PatrickGSR94's Avatar
Huh? That's how the tool works. It goes on the outside face of the RTA, and pushes the old bushing out the back side of the RTA. Then it pushes the new bushing in from the front side of the RTA.
Old 04-26-2010, 07:51 PM
  #104
92integraVTECgsr's Avatar
I'm confused as to how using a straight edge and marking it that way is any different from marking the top and bottom where the arrow is?
I borrowed my friends tool who is a tech at Acura and also builds some pretty nice cars and he said all I had to do was mark the top and bottom and measure how far it was sticking out.
I think I'm gonna mark it with a straight edge with the car on the ground, then mark the top and bottom and then check to see if the markings I made with the straight edge have changed once I lower the RTA.
Old 04-27-2010, 05:06 AM
  #105
When the LCA is bolted onto the car, the tab thru the bushing is stationary while the bushing outer race moves with the LCA, and the rubber flexes. So you need to put a straightedge on the tab and make marks on the LCA at ride height to get the proper orientation for the bushings.
Note that this is easier said than done. I had my car up on jack stands with a jack under the suspension (hub measured to fender to ensure actual ride height), no tire, and I still had a difficult time getting a straight edge under there and making a mark on the LCA. I actually had to mark one side only, then once the LCA was off the car, put the straightedge back on the bushing, flex the mounting tab with a screwdriver until the first mark lined up, then made a mark on the other side.
Old 07-17-2011, 09:04 AM
  #106
PhatOptimo's Avatar
get er done... i need this tool. If anyone can help i'd hepl$. email pls.
albertdiaz3
Suspension & Brakes
11
11-26-2014 04:42 PM
delsolo95
Suspension & Brakes
11-21-2014 08:12 PM
bank2me
08-19-2011 06:53 PM
jash
16
07-12-2010 03:55 AM
Thrillhouse
20
10-25-2005 09:26 PM
Quick Reply: How To: Replace Rear Trailing Arm Bushing- Cool Tool I found Saves Allot of time
