Suspension & Brakes Theory, alignment, spring rates....
ITR 4x114.3 Conversion to Prelude Brakes
Old 09-27-2017, 12:58 PM
forbiddenera's Avatar
Default ITR 4x114.3 Conversion to Prelude Brakes
Hey so I have the 4x114.3 swap on the front.
My rotors are old and I donated my new pads and old calipers to my sedan..
So I wanted to go to the 11" prelude brakes..
Everyone says 92-96 prelude vtec rotors.. check.. and ITR (5Bolt) calipers .. supposedly 17CL15VN ?
I've also read that the Prelude vtec calipers are also 17CL15VN .. is this correct?
I'm considering ordering a PowerStop Z26 Street Warrior kit that comes with new powder coated calipers, rotors and pads..it's advertised as a performance kit and I haven't read any reviews for them on a Honda..for the price I'm willing to try the kit, it's less than reman'd calipers and new rotors/pads from a local parts store..$350 Canadian shipped..
I'll order it right now if I knew it​​​d fit
Old 10-03-2017, 07:06 PM
1996accordlx's Avatar
Default Re: ITR 4x114.3 Conversion to Prelude Brakes
The calipers should be the same. The ITR, Prelude VTEC, and Accord V6/wagons I believe all shared the same larger single piston calipers. What varied was the brackets, based on the rotor thickness....23T vs 25T, etc. I believe both the ITR and Prelude use 23mm thick rotors, meaning you should already have the 23T brackets needed to work.
jomama
11-14-2006 06:06 PM
dc2gsr96
03-05-2006 12:44 PM
0ptimus prime
11-27-2005 11:42 AM
EK4door
28
05-17-2004 07:45 PM
ijjz
09-02-2002 08:59 PM
Quick Reply: ITR 4x114.3 Conversion to Prelude Brakes
