Ground Control Coil's
Old Mar 19, 2002 | 06:37 AM
TeamTooQuick's Avatar
Default Ground Control Coil's
I am planning on getting the adjustable Ground Control coil's and i am wondering if i can install it my self, or would i need someone else 2 do it, and if i can what toosl would i need 2 install them... TIA
Old Mar 19, 2002 | 07:22 AM
InfamousRS's Avatar
Default Re: Ground Control Coil's (TeamTooQuick)
They arnt that hard to install, you just need to have a basic idea of how things work and where the parts go. If its your first time installing springs, you may want to find someone to give you a hand who has done it before.
Old Mar 19, 2002 | 07:40 AM
Fooser's Avatar
Default Re: Ground Control Coil's (BLK94RS)
It goes alot easier if you have a friend help. usually just to put the rotor down so you can pull out the stock strut.
Old Mar 19, 2002 | 06:03 PM
joejohnson's Avatar
Default Re: Ground Control Coil's (Fooser)
Easy easy easy. The funnest part of that install is shooting the springs off the stock shock, but becareful and point that bad boy away from you or anybody when you take the cap off.
Old Mar 22, 2002 | 05:51 AM
Default Re: Ground Control Coil's (joejohnson)
Can i use my stock shocks with the g/c's??
Old Mar 22, 2002 | 07:10 AM
Rainmaker's Avatar
Well, it really depends what spring rates you ordered, but not recommended. Unless you ordered some really soft springs, you'll need shocks that are 1) stiffer, and 2) designed to work well with shorter springs.
Rainmaker.
PatrickGSR94
Suspension & Brakes
108
Jan 6, 2026 11:15 AM
TylerC161
Mar 28, 2007 06:17 PM
JoshRambo
May 12, 2003 05:15 PM
Canonm7
May 8, 2003 06:27 AM
Brewer
Feb 7, 2002 07:37 PM
